User-based Dynamic Access Control Lists
(ACL)
The user-based dynamic policy access control lists (ACL) feature uses the
existing RADIUS Access-Accept and change of authorization (CoA) mechanism to override
existing policy rules associated with a user by including a new vendor specific
attribute (VSA) in the CoA and Access-Accept. When a CoA request or Access-Accept
response to apply a particular set of match conditions and actions (or an action-set) is
received, a look-up is performed to determine which policy profile the specified user
was authenticated in, and the action-set ID specified in the CoA/Access-Accept is
applied in that user‘s profile.
You
must configure VCAP partitioning to use dynamic ACL (see
VCAP Partitioning).
If ACL style policy is not selected, or if the specified action-set does not
exist, or if insufficient resources are available, the dynamic ACL rules are not applied
and a NAK response to the RADIUS CoA request are returned. The maximum number of Dynamic
ACL rules per user is 64. Access-Accept can include multiple adds using the += operation (this
operation is not supported as part of RADIUS CoA request). Access-Accept usage does not
support delete operation is ignored. Dynamic ACL rules can be deleted using an explicit
CoA delete or are deleted when the dynamic session associated with the user is deleted.
The maximum length of a RADIUS packet size is 4096 (both UDP and TLS),
which can prevent the Dynamic ACLs from being sent to get trimmed via VSA 232 due to the
lengthier ACL lists.
Dynamic ACLs and Layer 7 policy share the slices not used by TCI
overwrite-enabled as one shared resource pool (see VCAP Partitioning). Dynamic ACLs have a higher priority to override Layer 7 policy
(DNS) entry matches.
Beginning with Release 32.1, masking IPv4 addresses, L4 ports, and IP protocol
numbers are supported. The mask is a required value and must be greater than zero and
less than or equal to the maximum number of bits in the field being masked. For example,
an IPv4 address mask value must be between 1 and 32.
The following match conditions can be used with user-based ACLs:
- ipv4src ipv4source/mask-length
- ipv4dst ipv4dest/mask-length
- ipproto ipproto
(TCP, UDP, ICMP, or protocol number)
- l4srcport l4sourceport/mask-length
(requires ipproto; range is role-based only with no mask)
- l4dstport l4destport-i4sourceportend/mask-length
- ether (role-based
only)
- any
The following actions can be used:
- CoS (not valid if “drop” is
specified)
- Drop (not valid if “forward” is
specified)
- Forward (not valid if “drop” is
specified)
- Syslog
- Mirror
To see an example of dynamic ACL VSA string, see Example Dynamic ACL VSA String.
Supported Platforms
All ExtremeSwitching Universal platforms.
- Dynamic Access-List is
not supported on the 5520 switch.
- DNS is not supported
on Extended Edge switches with Controlling Bridges on the ExtremeSwitching 5420
and 5520 series switch.
- ACL style policy must be
selected.
- Only a subset of the existing
policy rules is allowed.
- SNMP is not supported.
